8266EX Module with MicroPython in continous loop & REPL non responsive
OptimusGREEN
Re: 8266EX Module with MicroPython in continous loop & REPL non responsive
Post by OptimusGREEN » Wed May 06, 2020 2:26 pm
http://micropython.org/resources/firmwa ... -v1.12.bin
The latest stable one is the one I tried. I actually tried a couple of others too but was the same problem.
I then reflashed tasmota and an Arduino sketch to confirm MC was fine which it is.
Post by pythoncoder » Thu May 07, 2020 4:58 am
I think that's the wrong build. You need https://micropython.org/resources/firmw ... d419ba.bin or https://micropython.org/resources/firmw ... ef200b.bin. The first is release build 1.12 and the second is today's daily build.
OptimusGREEN
Post by OptimusGREEN » Thu May 07, 2020 6:18 am
Unfortunately same outcome with both those builds. here is the output...
chksum 0x0c
load 0x3ffe8000, len 1004, room 0
tail 12
chksum 0xea
ho 0 tail 12 room 4
load 0x3ffe83f0, len 1064, room 12
tail 12
chksum 0x81
csum 0x81
���o�;��'<�d
            $l$ ��s�d�$
                       l`��{�l�l
                                $ ��s�d
                                          $d`{l��rl���c��c�cc{�s
        �g�n�$��
        $�d��l$��Ą���d�n�����#ld�{p
        ����#l�c{l;l;�'���
        ��g����#;����dl�Performing initial setup
MicroPython v1.12-434-ge2def200b on 2020-05-07; ESP module (1M) with ESP8266
Post by Roberthh » Thu May 07, 2020 7:28 am
At the end you get the REPL. Can you use that?
Ignore the rubbish before the MicroPython start message. That's typical for ESP8266, sending the bootlog at 74880 baud.
OptimusGREEN
Post by OptimusGREEN » Thu May 07, 2020 7:54 am
No, it's available for a split second then loops again.
Trkcat
Post by Trkcat » Thu May 21, 2020 9:21 pm
I've got the same issue as well, on three different nodeMCU boards (all ESP-12E (ESP8266MOD), 4M flash, CP2102, Amica brand). I've tried flashing them to both v1.9.1 and v1.12, on two different computers (one linux, one Win10). Tried with all the different flash modes.
Same issue every time, REPL will accept maybe a character or two, freeze, and then restart due to the watchdog timer. I've tried using puTTY, Coolterm, pyserial miniterm, and upycraft to connect, all show the same behavior, so I believe it to be on the board side. Loops through the restart cycle roughly every 9 seconds. I also tried one poster's suggestion of reading the flash and then writing back (both with wiping the erasing the board flash in between and not) without success.
I offer no solutions at this point, but wanted to let you know there is another person out there with the same issues.
One final note, as one poster said, I reflashed one of them to the nodeMCU binary, and successfully uploaded and got the Arduino blink program to work.
