I just found MAX30102 (I2C with two leds) pulse sensor into my collection.
Thought for trying to use it with micropython.
Anybody have any idea about library of it ?
If anyone know it please provide link for same.
Thank You,
MAX30102 Sensor
Re: MAX30102 Sensor
hello
try this one
https://github.com/kandizzy/esp32-micropython
with main file like this
try this one
import machine, network, utime, neopixel, time
import ubinascii
from pye import pye
from ppg.MAX30105 import ParticleSensor
from ppg.heartbeat import HeartBeat
# gpio==
from machine import Pin, ADC #ws2812, piezo
np = neopixel.NeoPixel(Pin(16), 4, timing=1)
adc = ADC(Pin(34))
print("")
print("Starting WiFi ...")
sta_if = network.WLAN(network.STA_IF); sta_if.active(True)
sta_if.connect("workshops", "floating")
utime.sleep_ms(100)
print("WiFi started")
utime.sleep_ms(500)
mac = ubinascii.hexlify(network.WLAN().config('mac'),':').decode()
rtc = machine.RTC()
print("Synchronize time from NTP server ...")
rtc.ntp_sync(server="hr.pool.ntp.org")
while not rtc.synced():
utime.sleep_ms(100)
print("Time set")
utime.sleep_ms(500)
t = rtc.now()
print(str(t[3])+':'+str(t[4])+':'+str(t[5])+' '+str(t[2])+'/'+str(t[1])+'/'+str(t[0]))
print("")
def red():
print("red")
n = np.n
for i in range(n):
np[i] = (255, 0, 0)
np.write()
def green():
print("green")
n = np.n
for i in range(n):
np[i] = (0, 255, 0)
np.write()
def blue():
print("blue")
n = np.n
for i in range(n):
np[i] = (0, 0, 255)
np.write()
def off():
n = np.n
for i in range(n):
np[i] = (0, 0, 0)
np.write()
threshold = 100
color = (255,0,0)
def blink(color):
for i in range(np.n):
np[i] = color
np.write()
time.sleep(.01)
np[i] = (0, 0, 0)
np.write()
def listen():
#print(adc.read())
if adc.read() < threshold:
blink(color)
def main():
print("mac address", mac)
off()
# this should only be enabled on the red light mode
MAX30105 = ParticleSensor(HEX_ADDRESS=0x57)
part_id = MAX30105.i2c_read_register(0xFF)
rev_id = MAX30105.i2c_read_register(0xFE)
print("MAX30105: part ID", hex(ord(part_id)), "revision:", ord(rev_id))
print("Setting up sensor now:", '\n')
MAX30105.setup_sensor()
MAX30105.setPulseAmplitudeRed(0x0A)
MAX30105.setPulseAmplitudeGreen(0x00)
HearRateSensor = HeartBeat()
rates = [0] * 4
rateSize = len(rates)
rateSpot = 0
lastBeat = 0
listen()
lastBeat = time.ticks_ms()
for FIFO_pointer in range(32):
#try:
sensor_data = MAX30105.read_sensor_multiLED(FIFO_pointer)
#print("sensor_data", sensor_data)
irValue = int(sensor_data[1])
# red led will be greater than 50000 if your finger is on the sensor
if (sensor_data[0] < 50000):
rates = [0] * 4
rateSpot = 0
# print("hr ir:", irValue, "red:", sensor_data[0])
if (HearRateSensor.checkForBeat(irValue)):
print("beat")
delta = time.ticks_diff(time.ticks_ms(), lastBeat)
beatsPerMinute = 60 / (delta/1000)
if (beatsPerMinute < 255 and beatsPerMinute > 20):
if (rateSpot > 3):
rateSpot = 0
rates[rateSpot] = beatsPerMinute
rateSpot += 1
print("rates", rates)
beatAvg = 0
for x in range(rateSize):
beatAvg += rates[x]
beatAvg /= rateSize
print (beatAvg)
except (KeyboardInterrupt):
print('\n', "Exit on Ctrl-C: Good bye!")
finally:
print('\n', "Disconnecting.")
if __name__ == "__main__":
main()
