machine.reset(0 output
On my ESP32 when I do machine.reset() or press the RST button, I get readable output on my terminal. On the ESP8266, I gets unreadable characters. Any way to get readable output? I am using rshell with the default baud rate. Thanks.
Re: machine.reset(0 output
The ESP's bootloader runs at a different baud rate. (74880 iirc) so your UART/USB adaptor running at 115200 will not be able to read it. Once MicroPython starts it switches to 115200, and you should see the banner and prompt.
