Corrupt file stops boot
simonmcc
Post by simonmcc » Fri Jul 19, 2019 6:49 am
I have two D1 minis running a lightswitch for me, one is the sender and one the receiver. The receiver runs picoweb, and waits on /on or /off http requests to turn the lights on or off
It stopped working recently, and when I went to investigate I saw that the program file had been corrupted, it looks like the first part of it is gone:
How it should look:
import picoweb
import os
gc.collect()
import uasyncio as asyncio
How it actually looks:
 os
gc.collect()
And when I reboot it, I see this:
MPY: soft reboot
  File "main.py", line 1, in <module>
  File "<string>", line 2, in <module>
ImportError: no module named 'pcoweb'
MicroPython v1.11-72-g9cebead27-dirty on 2019-06-28; ESP module with ESP8266
I reloaded the original file to it, rebooted it and now it works fine.
My question is, what could have went wrong, and could it happen again? Is it bad flash, or a bad D1? Should I 'retire' it and try another one?
Re: Corrupt file stops boot
Post by jimmo » Fri Jul 19, 2019 7:07 am
Does your code write to the filesystem during normal operation? Was there possibly a power outage (or if it's battery powered, a low battery state) that coincides with the corruption?
simonmcc
Post by simonmcc » Fri Jul 19, 2019 7:21 am
I have a config module which allows the mode (transmitter/receiver) and wifi details etc to be configured, but these are not normally written unless someone clicks 'save' on the gui.
I don't think there was any power outage, our house alarm normally notifies us of something like that :)
It is currently powered from a Raspberry Pi, as I wanted to keep an eye on the console, so I used USB on the pi so I can watch the console (piped to a file on the pi)
Apart from that it just sits and waits for incoming requests for /on and /off
