my script gets blocked when there's a watchdog
palouf34
Post by palouf34 » Sat Aug 10, 2019 9:02 am
I have a recurring problem with my script despite the watchdog found on one of the topics on this forum.
I'm trying to do the following operations:
this is my script:
#station meteo
#import standard library
import urequests
# import special library
import bme280
import veml7700
#start configuration machine
#machine.freq(160000000) # set the CPU frequency to 160 MHz
# configure RTC.ALARM0 to be able to wake the device
rtc = machine.RTC()
rtc.irq(trigger=rtc.ALARM0, wake=machine.DEEPSLEEP)
#end of configurartion machine
# address  of external captor
bme280_addr = 0x76
vmle7700_addr = 0x10
# variable pour jeedom
apiKey = "ezrz"
idPa = "1551"
idTemp = "1552"
idHumidity = "1553"
idLux = "1562"
host = "192.168.8.204"
nbrReset = "1713"
port = 80
baseurl = "http://"+host+"/core/api/jeeApi.php?apikey="
baseurl += apiKey
baseurl += "&type=virtual&id="
#variable  des mesure
t_old = 0;
lux_old = 0.0;
h_old = 0;
pa_old = 0.0;
#mise en place du watchdog
# issus de https://forum.micropython.org/viewtopic.php?f=16&t=5517&hilit=esp8266+sleep+and+reset&start=10
# second exemple de watchdod
# issus de  https://forum.micropython.org/viewtopic.php?f=16&t=6376
class WDT:
    def __init__(self, id=0, timeout=600):
        self._timeout = timeout / 10
        self._counter = 0
        self._timer = machine.Timer(id)
        self.init()
    def _wdt(self, t):
        self._counter += self._timeout
        if self._counter >= self._timeout * 10:
            machine.reset()
    def feed(self):
        self._counter = 0
    def init(self, timeout=None):
        timeout = timeout or self._timeout
        self._timer.init(period=int(self._timeout * 1000),
                         mode=machine.Timer.PERIODIC, callback=self._wdt)
    def deinit(self):  # will not stop coroutine
        self._timer.deinit()
# fin du watch dog
## END Simple software WDT implementation
# activate i2c port
i2c = machine.I2C(scl=machine.Pin(5),sda=machine.Pin(4))
#create  capteur "object"
capteur2_lumiere = veml7700.VEML7700(vmle7700_addr,
                                     i2c,
                                     "confValues25_18",
                                     "gain25_18")
capteur_bme = bme280.BME280(i2c=i2c)
wdt = WDT()
#start software
def main():
  #start scan i2c buss
  print('Scan i2c bus...')
  devices = i2c.scan()
  if len(devices) == 0:
    print("No i2c device !")
    print('i2c devices found:',len(devices))
    for device in devices:
      print("Decimal address: ",device," | Hexa address: ",hex(device))
  #end scan i2c bus
  boucle=0
  cptReset = 0
  print("debut calcul")
  #while boucle<5:
    wdt.feed()
    i=0
        print("s'est réveillé d'un profond sommeil")
    while i<50:
      # programmation du capteur
      #lecture de la valeur du capteur
      mesure_lux = capteur2_lumiere.read_lux()
      #print("valeur multiplicateur: ",capteur2_lumiere.confValues)
      #print("valeur gain : ", capteur2_lumiere.gain)
      #print("Valeur VLME7700 : ")
      #print("la mesure est  de ", mesure_lux, " lux")
      time.sleep(1)
      # affichage des infos BME280
      #print("température ,  pression, higronometrie :")
      temperature =  capteur_bme.values[0]
      temperature = temperature[:-1]
      #print(temperature)
      pression = capteur_bme.values[1]
      pression = pression[:-3]
      #print(pression[:-3])
      humidite = capteur_bme.values[2]
      humidite= humidite[:-3]
      #print(humidite[:-1])
      i=i+1
      print("Fin boucle de prise de mesure, tour numero :", i)
    #print("Valeurs deniere mesure")
    #print("la mesure est  de luminosité est de  ", mesure_lux, " lux")
    #print(temperature)
    print("J'envoie les données à jeedom")
    print("Tempreature envoyé",temperature)
    print("Pression envoyé",pression[:-3])
    print("Taux d'humidité envoyé",humidite[:-1])
    print("taux de lumiére envoyé",mesure_lux)
    # constitution base du get  pour envoie a jeedom
    #baseurl = "http://"+host+"/core/api/jeeApi.php?apikey="
    #baseurl += apiKey
    #baseurl += "&type=virtual&id="
    # constitution  url d'envoie
    url = baseurl + idTemp # id jeedom  objet
    url += "&value="
    url += temperature; # valeur récuperer  du capteur
    response = urequests.get(url)
    #pression
    url = baseurl + idPa # id jeedom  objet
    url += "&value="
    url += pression[:-3]; # valeur récuperer  du capteur
    #humidite
    url = baseurl + idHumidity # id jeedom  objet
    url += "&value="
    url += humidite[:-1] # valeur récuperer  du capteur
    # lux
    url = baseurl + idLux # id jeedom  objet
    url += "&value="
    url += str(mesure_lux); # valeur récuperer  du capteur
    print("transmission faite")
    #print(type(mesure_lux))
    #print("je m'endors pour quelques minutes")
    #mise en place du deepsleep
    # set RTC.ALARM0 to fire after 10 seconds (waking the device)
    #print("nous en sommes a la boucle: ",boucle )
    wdt_timer = machine.Timer(-1)
    wdt_timer.init(period=275000, mode=machine.Timer.PERIODIC,
                callback=lambda t: wdt_callback())
if __name__ =="__main__":
      main()
relaunch my script like this
Meteo import >>> Meteo import
>>> Meteo.main
AttributeError:'module' object has no attribute' main
I reboot the esp, I do lose some ping but the scipt does not restart.
I have to physically restart the nodemcu.
I have however the rst pin connected with the D0 pin.
Do you have any idea where my problem comes from.
manseekingknowledge
Re: my script gets blocked when there's a watchdog
Post by manseekingknowledge » Sun Aug 11, 2019 3:26 am
Are you asking about this error?
If so then you need to call main as a function. and make sure you use the correct import syntax. Instead of:
Metro import
Meteo.main
Use
import Metro
Meteo.main()
palouf34
Post by palouf34 » Sun Aug 11, 2019 12:44 pm
sorry a see you response so later, I'm reboot my nodemcu before.
but I restet this for futur problem.
