Adafruit Feather Huzzah esp8266 not running MicroPython
mleefers
Post by mleefers » Tue Aug 20, 2019 10:48 pm
I am trying to put the MicroPython firmware on my new feather Huzzah and I can flash the firmware fine and it seems to be successful but when I go to start the REPL in PuTTY I am getting a weird flashing line. I have attached some screenshots from flashing, PuTTY configs. and PuTTY console. I was able to flash it with CircuitPython and it worked fine but for some reason MicroPython is not working.
PuTTY console screen (Its flashing that one line very fast)
PuTTY configs
command console after firmware flash
manseekingknowledge
Re: Adafruit Feather Huzzah esp8266 not running MicroPython
Post by manseekingknowledge » Wed Aug 21, 2019 1:13 am
The speed in your putty config looks correct, but every time I've seen the writings of Cthulhu in a terminal when attempting a serial connection it was because I had the speed wrong.
Post by jimmo » Wed Aug 21, 2019 5:49 am
Probably not the reason, but have you tried using the latest version, v1.11?
If you press enter a few times at the terminal, does the prompt appear?
mleefers
Post by mleefers » Wed Aug 21, 2019 12:48 pm
Yeah, I've tried both versions and tried enter a few times in the console. Nothing seems to respond in the PuTTY console.
Post by jimmo » Wed Aug 21, 2019 1:16 pm
And you've tries ctrl-c also?
Hrmm... I wonder... did you do an erase_flash before programming? Might be worth trying?
mleefers
Post by mleefers » Wed Aug 21, 2019 1:30 pm
I guess I didn't try ctl-c. I'll have to try that later (I'm at work now haha). I did erase the flash and re-flashed multiple times.
Post by Roberthh » Wed Aug 21, 2019 1:40 pm
Did you switch flow control in Putty off?
mleefers
Post by mleefers » Wed Aug 21, 2019 2:17 pm
I have not messed with the flow control at all. currently it is set to XON/XOFF. Are you saying maybe I should try no flow control? I'm not sure what RTS/CTS or DSR/DTR actually are.
Post by Roberthh » Wed Aug 21, 2019 2:18 pm
Set it to no glow control.
mleefers
Post by mleefers » Thu Aug 22, 2019 1:22 am
That did it for me. Thank you!
