Door sensor with ESP8266
vektra112
Post by vektra112 » Thu Oct 10, 2019 5:49 pm
Hello!
I'm new to programming esp boards but I'dont know if problem is with my wiring or the code.
I've connected sensor to the GND and D02 and when the doors are closed it should open link and go to deep sleep. Instead it stays open all the time.
Here is the code:
import os
import urequests
from time import sleep
def connect():
    ssid = ""
    password =  ""
    station = network.WLAN(network.STA_IF)
    if station.isconnected() == True:
        print("Already connected")
        return
    station.active(True)
    station.connect(ssid, password)
    while station.isconnected() == False:
        pass
    print("Connection successful")
    print(station.ifconfig())
connect()
time.sleep(1)
p2 = Pin(2, Pin.IN)
while p2.value()==1:
  response=urequests.post("http://somer_link")
  time.sleep(10)
    response=urequests.post("http://other_link")
    time.sleep(5)
    machine.deepsleep()
Thank you!
vektra112
Re: Door sensor with ESP8266
Post by vektra112 » Thu Oct 10, 2019 7:01 pm
I found the problem. It was code and the wiring. I've changed it to Pin5 which is GPIO1 and the code is this.
import os
import urequests
def connect():
    ssid = ""
    password =  ""
        return
        pass
connect()
time.sleep(1)
p5 = Pin(5, Pin.IN, Pin.PULL_UP)
while p5.value()==1:
  response=urequests.post("http://")
  time.sleep(10)
    time.sleep(5)
    machine.deepsleep()
kevinkk525
Post by kevinkk525 » Thu Oct 10, 2019 9:15 pm
Glad you found the solution.
Kevin Köck
ghayne
Post by ghayne » Sun Oct 13, 2019 8:56 am
You may have problems with GPIO1 as it is the RX pin. It is high at boot and boot will fail if it's held low at boot time.
This is a good reference for which GPIO's you should use on the ESP8266
https://randomnerdtutorials.com/esp8266 ... nce-gpios/
