ntp time
bellad
ntp time
Post by bellad » Fri Oct 18, 2019 9:36 am
hello,
i try with ntptime.py and i change
machine.RTC().datetime((tm[0], tm[1], tm[2], tm[6] + 1, tm[3], tm[4], tm[5], 0))
by
machine.RTC().datetime((tm[0], tm[1], tm[2], tm[6]+1, tm[3]+2, tm[4], tm[5], 0))
with utime.localtime()
the first :
(2019, 10, 18, 5, 9, 21, 10, 0)
good for weekday
the second :
(2019, 10, 18, 11, 21, 17, 4, 291)
good for utc + 2h but no good for weekday
i no understand
kevinkk525
Re: ntp time
Post by kevinkk525 » Fri Oct 18, 2019 9:47 am
I use this:
RTC_TIMEZONE_OFFSET=1
ntptime.settime()
tm = time.localtime()
tm = tm[0:3] + (0,) + (tm[3] + RTC_TIMEZONE_OFFSET,) + tm[4:6] + (0,)
machine.RTC().datetime(tm)
Kevin Köck
bellad
Re: ntp time
Post by bellad » Fri Oct 18, 2019 11:08 am
ok thank's
but why the weekday is 4 instead of 5
4 = Thursday
5 = Friday
what do you have a weekday ?
kevinkk525
Re: ntp time
Post by kevinkk525 » Fri Oct 18, 2019 1:10 pm
The weekday is consistent with the CPython3 output. I would have expected it to be 5 but apparently 4 is correct:
https://docs.python.org/3/library/time. ... truct_time
Monday is 0.
Being used to crontab I expected Sunday to be 0 but python thinks differently.
Kevin Köck
bellad
Re: ntp time
Post by bellad » Fri Oct 18, 2019 1:20 pm
ok , thank for info ,
it's very strange , but we are going to do with ,
by adding +1 for weekday and ,for me ,adding +2 for the hour
kevinkk525
Re: ntp time
Post by kevinkk525 » Fri Oct 18, 2019 1:24 pm
I wouldn't modify the weekday to stay compatible to the typical Python implementation but that's your choice..
Kevin Köck
bellad
Re: ntp time
Post by bellad » Fri Oct 18, 2019 2:08 pm
but i no understand , today we are friday
the micropython today is 4
if i look at utime function
utime.localtime([secs])
Convert a time expressed in seconds since the Epoch (see above) into an 8-tuple which contains: (year, month, mday, hour, minute, second, weekday, yearday) If secs is not provided or None, then the current time from the RTC is used.
year includes the century (for example 2014).
month is 1-12
mday is 1-31
hour is 0-23
minute is 0-59
second is 0-59
weekday is 0-6 for Mon-Sun
yearday is 1-366
we should be the number 5
rpr
Re: ntp time
Post by rpr » Fri Oct 18, 2019 2:19 pm
0 = Monday.
bellad
Re: ntp time
Post by bellad » Fri Oct 18, 2019 2:21 pm
yes , we are friday = 5
utime.localtime()
kevinkk525
Re: ntp time
Post by kevinkk525 » Fri Oct 18, 2019 2:50 pm
utime.localtime()
Monday: 0
Tuesday: 1
Wednesday: 2
Thursday: 3
Friday: 4
Kevin Köck
