bmp180
bellad
bmp180
Post by bellad » Tue Nov 12, 2019 2:16 pm
hello,
i try read a bmp180 , i downloaded bmp180.py
from bmp180 import BMP180
from machine import I2C, Pin
bus =  I2C(scl=Pin(4), sda=Pin(5), freq=100000)
with i2c.scan() = [118]
i have changed , in bmp180.py ,
_bmp_addr = 119
by
_bmp_addr = 118
but
bmp180 = BMP180(bus)
  File "bmp180.py", line 22, in __init__
OSError: [Errno 19] ENODEV
I do not understand why
can you help please
ghayne
Re: bmp180
Post by ghayne » Tue Nov 12, 2019 2:21 pm
I looks like your BMP180 is not connected properly, check the wiring.
bellad
Re: bmp180
Post by bellad » Tue Nov 12, 2019 2:25 pm
i think of yes , because with i2c.scan() = 118
ghayne
Re: bmp180
Post by ghayne » Tue Nov 12, 2019 2:41 pm
I think
should be
I2C(scl=Pin(5), sda=Pin(4), freq=100000)
Garry
bellad
Re: bmp180
Post by bellad » Tue Nov 12, 2019 2:51 pm
ok i put I2C(scl=Pin(5), sda=Pin(4), freq=100000)
same error
bellad
Re: bmp180
Post by bellad » Tue Nov 12, 2019 3:02 pm
it's ok , i download for bme280 :
it's good
thank you
