ESP-01 I2C
ta1db
ESP-01 I2C
Post by ta1db » Sat Nov 16, 2019 2:23 pm
Would anyone kindly help me to run machine.I2C module on ESP-01
Which pin numbers should I use for GPIO0 and GPIO2 ?
I found an example here : https://www.dobitaobyte.com.br/i2c-com- ... cropython/ like that
sda = Pin(12)
scl = Pin(14)
i2cbus = I2C(scl,sda)
if I am not wrong the Pin(12) is not available on ESP-01.
Here https://primalcortex.wordpress.com/2015 ... -01-board/ it says ESP8266 can create and use an I2C bus on GPIO0 GPIO2 pins, here https://www.forward.com.au/pfod/ESP8266 ... magic.html the writer talks about ESP8266-01 Pin Magic; however I couldn't find a way to implement it in MicroPython.
I appreciate your help.
Re: ESP-01 I2C
Post by Roberthh » Sat Nov 16, 2019 3:47 pm
GPIO0 is Pin(0), GPIO2 is Pin(2). Both must not be 0 upon boot for normal opeartion, but pulling them up for I2C is no problem. So your code snippet would e.g. be
scl_pin = Pin(0)
sda_pin = Pin(2)
i2cbus = I2C(scl=scl_pin, sda = sda_pin)
I used scl_pin and sda_pin to point at the difference between a keyword parameter and the name of the variable.
ta1db
Re: ESP-01 I2C
Post by ta1db » Sat Nov 16, 2019 7:18 pm
Thank you very much Roberth, it worked!
