Page 1 of 2
uPycraft with mpy file
Posted: Wed Dec 18, 2019 10:07 am
by bellad
i have compiled my file py in mpy with mpy-cross
it's possible to run mpy file with upycraft ?
if yes , how to ?
because i have
ValueError: incompatible .mpy file
thank you
Re: uPycraft with mpy file
Posted: Wed Dec 18, 2019 4:46 pm
by Roberthh
The versions of the firmware installed on your board and mpy-cross do not match. That's what the error tells.
Which firmware version do you have on the board, and which mpy-cross are you suing?
Posted: Thu Dec 19, 2019 9:13 am
by bellad
version firmware : esp8266-20190125-v1.10
mpy-cross.exe : Micropython v1.11 on 2019-09-15 ; mpy-cross emitting mpy v4
i have changed : esp8266-512k-20191219-v1.11-671-g0d82f5d8c.bin
it's the same !!
>>> exec(open('./chauf.mpy').read(),globals())
File "<string>", line 1
SyntaxError: invalid syntax
I don't know if I'm doing the right thing
Posted: Thu Dec 19, 2019 11:17 am
by Roberthh
I updated mpy-cross.exe here
https://github.com/robert-hh/Shared-Stuff to a today's build. Then it should match.
Posted: Thu Dec 19, 2019 12:12 pm
by Christian Walther
I don’t think exec() takes mpy content. Have you tried running it using import chauf?
Posted: Thu Dec 19, 2019 12:28 pm
by bellad
thank's , i will try mpy-cross
Christian , my prog chauf at wihle true , if i do import chauf , how to after for the start ?
Posted: Thu Dec 19, 2019 3:09 pm
by bellad
hello Robert
i've updated with your myp-cross ,same
i think i idoes not do well
can you tell me how to ?
Posted: Thu Dec 19, 2019 3:15 pm
by Roberthh
I agree to @Christian Walther, in that exec expects python source, not pre-compiled files.
At least,
import chauf
should run the file chauf.mpy.
Posted: Thu Dec 19, 2019 3:26 pm
by bellad
ok , thank
i wil try with 'print' , because nothing is happening and I see nothing
i can't try with chauf.py because
MemoryError: memory allocation failed, allocating %u bytes
Posted: Thu Dec 19, 2019 9:36 pm
bellad wrote: ↑Thu Dec 19, 2019 12:28 pm
I’m sorry, I don’t understand this sentence, can you rephrase? (Or – “chauf” sounds French – try in French?)
