Build how to?!?
jedie
Re: Build how to?!?
Post by jedie » Mon Dec 30, 2019 5:31 pm
How i have a own working firmware with freezed modules. Nice. But it's not really practical without OTA Updates.
It seems a pure python solution is not possible, see: viewtopic.php?f=2&t=7468
So the only way seems to be yaota8266: viewtopic.php?f=16&t=3262
On the other side: For me it looks like, that yaota8266 project it not really good maintained, see: https://github.com/micropython/micropyt ... -569740745
So how to build an OTA firmware and how to perform the OTA update???
I will take a look into: https://schinckel.net/tags/yaota/
jomas
Re: Build how to?!?
Post by jomas » Tue Dec 31, 2019 11:57 am
I think the whole build procedure with 'open-esp-sdk' for the esp8266 should be updated.
1. It uses SDK-2.1.0 which is from 2017, so almost 3 years old. Even the latest version 3.0.0 will not be updated anymore.
Espressif will only supply bugfixes for 3.0.0.
2. Also Espressif advise to use the 'ESP8266 RTOS SDK'. (see README of https://github.com/espressif/ESP8266_NONOS_SDK)
3. The Xtensa compiler is build with standalone=y which makes it more difficult to integrate a new Espressif SDK.
I think the compiler (which works well) and the SDK's should be separated.
4. There are scripts used that only work with python2.
I think 1. is easy because there are already non implemented PR's.
3. Will need some extra includes I guess.
4. Should be easy too.
For 2. I really have no idea how to implement this.
jedie
Re: Build how to?!?
Post by jedie » Wed Jan 01, 2020 1:31 pm
Maybe, i don't know and this is beyond my ability.
I have at least got it together so that I can easily create the OTA firmware and yaota8266.bin see: viewtopic.php?f=5&t=7367&p=42704#p42704
In the end it's done by two docker images:
* Compile yaota8266.bin via docker: https://github.com/jedie/docker-yaota8266
* Compile micropython firmware via docker: https://github.com/jedie/docker-micropython
