docker-yaota8266
jedie
docker-yaota8266
Post by jedie » Tue Dec 31, 2019 2:10 pm
I have created https://github.com/jedie/docker-yaota8266 for easier generate a own yaota8266.bin via docker.
It used the docker image https://hub.docker.com/r/jedie/micropython builded via https://github.com/jedie/docker-micropython
I currently use a own fork: https://github.com/jedie/yaota8266 because of many missing patches. More info here: https://github.com/pfalcon/yaota8266/pull/27 see also: https://github.com/micropython/micropyt ... -569740745
Building yaota8266.bin is very easy.
1. Generate RSA keys:
~/docker-yaota8266& make rsa-keys
Copy&paste this RSA modulus line into your config.h:
#define MODULUS "\xce\x4a\xaf\x65\x0d\x4a\x74\xda\xc1\x30\x59\x80\xcf\xdd\xe8\x2a\x2e\x1d\xf7\xa8\xc9\x6c\xa9\x4a\x2c\xb7\x8a\x5a\x2a\x25\xc0\x2b\x7b\x2f\x58\x4c\xa8\xcb\x82\x07\x06\x08\x7e\xff\x1f\xce\x47\x13\x67\x94\x5f\x9a\xac\x5e\x7d\xcf\x63\xf0\x08\xe9\x51\x98\x95\x01"
2. Create own yaota8266/config.h and copy&paste the modulus line
3. compile final yaota8266.bin by:
~/docker-yaota8266& make compile
jedie
Re: docker-yaota8266
Post by jedie » Wed Jan 01, 2020 7:07 pm
I can build and flash the yaota8266 bootloader and micropython firmware...
The bootloader works halfway: I see the "OTA server" messages and it seems to wait connection... After timeout i see this messages: OTA start timeout, rebooting it reboots and the micropython interpreter starts and worked.
But i can't connect to the device in OTA mode, yet. Any idea?
I created https://github.com/jedie/micropython-so ... /issues/33 for this.
jedie
Post by jedie » Sat Jan 04, 2020 2:33 pm
Ah! I tried with TCP, but it's UDP, so i can't "see" the device :P
EDIT: Yes, that's it. With https://github.com/jedie/yaota8266/comm ... 13ae0d35ac i replaced my asyncio TCP AsyncConnector with a UDP broadcast solution... With this new implementation it's also possible to perform the OTA update without specifying the Device IP address! That's a enhancement of the origin code from pfalcon.
I send the first OTA package to broadcast 255.255.255.255 and after the device send the right response, all next packages goes only to the device IP.
