ESP12e: analog reading not working with voltage divider
djipey
Post by djipey » Sun Jan 05, 2020 3:53 pm
I'm trying to read from an analog sensor (a capacitive soil moisture sensor). I'm using a ESP12E, not a development board, so the ADC pin can only take 1V max. Since my sensor can output up to 3V, I need a voltage divider to not fry my board.
Here is my wiring:
https://imgur.com/4NYRfzt
Could you please confirm the wiring is ok?
I then use this code to read from the sensor:
from machine import Pin, ADC
from time import sleep
pot = ADC(0)
    pot_value = pot.read()
    print(pot_value)
    sleep(1)
However, the analog reading is always 0. When I disconnect the ADC pin, I get other, fluctuating values. So I think the problem comes from my voltage divider.
The sensor works with a ESP32 devkit board, so the problem doesn't come fro m the sensor (the devkit board has a voltage divider, so I didn't need to make one myself).
Re: ESP12e: analog reading not working with voltage divider
Post by pythoncoder » Sun Jan 05, 2020 4:56 pm
Can the sensor drive an impedance as low as 320Ω? It would help if you could measure the voltages coming from the sensor and going into the ADC.
djipey
Post by djipey » Sun Jan 05, 2020 5:32 pm
I'm a beginner in electronics so I'm not sure about what "Can the sensor drive an impedance as low as 320Ω?" really means.
But I can measure the voltages coming from the sensor, I have a multimeter. Directly from the sensor (no voltage divider), I have 2.5V when the sensor is in the air, and 1.2V when it's in water. When I measure the output of the voltage divider, I get 7 mV. That's really low. So I guess it answers your question.
What can I do to fix the problem?
djipey
Post by djipey » Sun Jan 05, 2020 6:50 pm
I got the divider to work, by using 2x 220k ohm resistors as R1 and a 470k ohm as R2. I span the range 420/975 mv (in water, in air) vs 1.2/2.5V (water, air) directly from the sensor. Thanks for spotting impedance was the problem.
MostlyHarmless
Post by MostlyHarmless » Sun Jan 05, 2020 6:54 pm
impedance == (effective) resistance (of a circuit)
In this case @pythoncoder meant the resistance of the entire voltage divider, which is 320Ω. The problem here might be that that is way too low of an impedance and for all practical purposes pulls your analog signal to ground, rather than dividing anything (technically it is still dividing something but not enough to measure it with the ADC).
What do you get from the sensor with the voltage divider attached? IOW the input, rather than the output of the voltage divider. My guesstimate is something around 21mV.
You can try using resistors with a higher resistance. Like 10KΩ and 22KΩ (or even 100KΩ and 220KΩ). The higher you go, the less the voltage divider will pull down your sensor signal, but at the same time the input impedance of the ADC pin itself will affect the voltage divider. This is because the ADC is actually a resistor wired in parallel to where you currently have the 100Ω. ADCs usually are around 1MΩ. That in parallel to 100Ω is insignificant. But it is significant with a 100KΩ because it changes that part of the voltage divider to effectively 90.9KΩ.
Regards, Jan
