DSMX 9645 Sattelite read data
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 7:25 pm
Hello Guys. Really happy to be a part of a such Great community!
I'm trying to read data from Spektrum DSMX 9645 remote receiver .
Maybe I do something wrong? But I receive only "None", even I disabled REPL.
Here is a code:
import uos
uos.dupterm(None, 1)  # Disables REPL(UART 0)
uart = UART(0, 115200)
uart.init(baudrate=115200, rx=machine.Pin(3),
          bits=8, parity=None, stop=1,
          timeout=100)
for i in range(100):
    with open('h.txt', 'a') as doc:
        doc.write(str(uart.read(16)) + '\n')
uos.dupterm(UART(0, 115200), 1)  # Enables REPL(UART 0)
On my ESP8266:
Orange -> VVC
Black -> GND
Gray -> connecter to RX(pin #3)
Thank you in advance!
Re: DSMX 9645 Sattelite read data
Post by Roberthh » Sat Jan 18, 2020 7:40 pm
The uart.read() may timeout fast. In the reading loop, you should first wait by calling uart.any(), until you receive some characters, and then call uart.read().
About the connection: I assume that you connect the orange wire to 3.3V Vcc, and that the idle state of the UART line is at a high level.
P.S.: 125000 Baud is odd. You may get errors when receiving with 115200 baud, which is 8% off.
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:00 pm
Thank you, Roberthh!
Yes, connected to 3.3V Vcc
Here is how it looks like:
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:15 pm
uart.any() doesn't help. I've added loops. It is always 0(zero)
Done, is better than perfect!
Post by Roberthh » Sat Jan 18, 2020 8:34 pm
Do you have any tools like oscilloscope or logic analyzer to visualize the signal on the data line? Or at least an DMM to tell the static signal level on the data line.
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:38 pm
Unfortunately I don't:(
I've found these similar examples:
https://github.com/samfok/remote_receiv ... er/main.py
https://github.com/stnbu/satbot/blob/ma ... ot/main.py
And it supposed to work
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:40 pm
Also this instruction
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:45 pm
Another thing is that the receiver is bound to a spektrum dx6 transmitter.
If the light is on on the receiver it should receive anything.
voskrresenskyi
Post by voskrresenskyi » Sat Jan 18, 2020 8:50 pm
Found an example with an oscilloscope
Post by Roberthh » Sat Jan 18, 2020 9:10 pm
So at least I can see, that is is "normal" level, and the ESP8266 should be able to receive it. But you still do not know, whether any data is actually exchanged.
