[SOLVED] async read keypressed in terminal
VladVons
Post by VladVons » Fri Feb 14, 2020 6:57 pm
i want to read in terminal keypressed while http server is running.
please hint me
Re: async read keypressed in terminal
Post by jimmo » Sat Feb 15, 2020 5:02 am
You can use select or poll on sys.stdin to see if there are characters available (which you can then read using sys.stdin.read).
More info here: viewtopic.php?f=18&t=6954&p=39455
VladVons
Re: async read keypressed in terminal [SOLVED]
Post by VladVons » Sat Feb 15, 2020 8:27 am
thanks jimmo
import uasyncio as asyncio
import sys
import select
async def Task1():
    print('Task1')
    await asyncio.sleep(1)
async def Task2():
    await asyncio.sleep(0.1)
    while sys.stdin in select.select([sys.stdin], [], [], 0)[0]:
        ch = sys.stdin.read(1)
        print('none block input char', ch)
loop.create_task(Task1())
loop.create_task(Task2())
loop.run_forever()
VladVons
Post by VladVons » Tue Jan 26, 2021 10:36 am
async non blocking keyboard input example
import sys
import select
def GetInputChr():
    R = ''
        R = sys.stdin.read(1)
    return R
async def GetInputStr(aPrompt = ''):
    R = ''
        K = GetInputChr()
        if (K):
            if (ord(K) == 10): # enter
                print()
                return R
            elif (ord(K) == 27): # esc
                return ''
            elif (ord(K) == 127): # bs
                R = R[:-1]
                R += K
        sys.stdout.write("%s%s   \r" % (aPrompt, R))
async def Test1():
        print('Test1')
        await asyncio.sleep(5)
async def Test2():
    S = ''
        print('Test2')
        S = await GetInputStr('Prompt: ')
        print('input', S)
loop.create_task(Test1())
loop.create_task(Test2())
loop.run_forever()
Post by pythoncoder » Wed Jan 27, 2021 7:07 am
Note that select.select is deprecated in favour of .poll or (usually more RAM efficient) .ipoll.
VladVons
Post by VladVons » Sun Feb 14, 2021 2:52 pm
Peter, no theme in internet
Hope I`m on a right way with select.poll()
class TKbdTerm():
    def __init__(self):
        self.Poller = select.poll()
        self.Poller.register(sys.stdin, select.POLLIN)
    def GetChr(self):
        for s, ev in self.Poller.poll(500):
            return s.read(1)
    async def Input(self, aPrompt = ''):
        R = ''
            K = self.GetChr()
            if (K):
                    print()
                    return R
                    return ''
                    R = R[:-1]
                    R += K
            await asyncio.sleep(0.2)
