unable to communicate with doit esp-12n developemebt board
jay2026
Post by jay2026 » Sat Feb 15, 2020 6:50 pm
I'm new to micro-python and microcontrollers I, recently borrowed this microcontroller from my friend to learn micro-python it is an esp-12n development board from the esp chip is from doit I'm using lunix mint to work with my board I followed the instructions of how to flash the latest bin file from the getting stared guide the flash was successful i used the command 'picocom -b 115200 /dev/ttyUSB0 to connect to the board it gets connected but im unable to see (>>>) on the screen did try different bin files but the results were no different please can anyone help me
Re: unable to communicate with doit esp-12n developemebt board
Post by Roberthh » Sat Feb 15, 2020 7:14 pm
Are you sure that you are using the right USB device?
jay2026
Post by jay2026 » Sun Feb 16, 2020 9:55 am
The developement board is having silabs cp2102 for serial to uart communication so all i have to do is plug and play im able to flash the bin file but unable to code
Post by Roberthh » Sun Feb 16, 2020 11:29 am
So
- you flashed the device using /dev/ttyUSB0, and there were no error messages. That should exclude any connection problems.
- there is no error message in accessing /dev/ttyUSB0 using picocom, like missing access right.
- you did not use any flow control options.
There were issues once with a modem manager. But the error patter was different. I just tried a Mint Linux VM with a board having a CP2104 chip, and that worked well.
Could you try to start picocom with the additional options --raise-rts --raise-dtr, just to sure that these lines are in a proper state.
jay2026
Post by jay2026 » Sun Feb 16, 2020 3:22 pm
So
sure sir i'll but what is the use of those commands im new to linux to so how am i to use it
Post by Roberthh » Sun Feb 16, 2020 7:21 pm
The command would be:
picocom -b 115200 --raise-rts --raise-dtr /dev/ttyUSB0
Another test:
If you start picocom and then push the reset button or connect reset to GND of the esp12, do you get some response from the device? it could be a sequence of strange characters.
Post by Roberthh » Sun Feb 16, 2020 7:24 pm
I just looked at the doit esp-12n. If it is just the module, make sure that you pull up en, rst and GPIO0.
jay2026
Post by jay2026 » Mon Feb 17, 2020 5:39 am
sir this is my boardImage
jay2026
Post by jay2026 » Mon Feb 17, 2020 5:40 am
but the esp chip is different
jay2026
Post by jay2026 » Mon Feb 17, 2020 5:42 am
Another test:
yes sir i get some garbage values in ascending steps format but im not getting this(>>>) to type my code
