Get caller method name from a stack
VladVons
Post by VladVons » Fri Feb 21, 2020 8:23 pm
within a function i want to know who called me
another words i want to trace stack
in python for PC there is a module 'inspect' and method 'stack()'
From there I can get a stack information:
File name
Caller method name
Method's line number
def MethodA():
    # some code to get a caller name
    # in my case it should be 'Main'
def Main():
    MethodA()
Re: Get caller method name from a stack
Post by jimmo » Sat Feb 22, 2020 12:02 am
This _might_ be possible by raising and catching an exception... but off the top of my head (on my phone atm) I can't remember if (or how) you can pull the traceback out of an exception object in MicroPython.
Post by jimmo » Mon Feb 24, 2020 12:56 am
I don't think this is possible. You can get the text of an exception (using sys.print_exception to a StringIO), but an exception traceback won't have the caller in it (as the traceback starts from the `try`). You could use this approach to find out the current method's name, but that doesn't seem very useful.
(Would love to be proven wrong though)
stijn
Post by stijn » Mon Feb 24, 2020 8:46 am
It would also be interesting if you post what exactly you actually want to achieve, just to avoid classic A/B problem situations.
VladVons
Post by VladVons » Mon Feb 24, 2020 12:56 pm
I use this trick for logging both message + caller
def Log(aMsg, aCallerName = 'unknown'):
  # to minimize code size it would be good to get a aCallerName from a stack here
  print(aMsg, aCallerName )
def Func1():
  Log('Message1', 'Func1()')
def Func2():
  Log('Message2')
stijn
Post by stijn » Mon Feb 24, 2020 1:56 pm
Yeah if you need that there's not many options except for calling Log() in callers as well.
VladVons
Post by VladVons » Mon Feb 24, 2020 5:03 pm
Two reasons:
1) Main is less code size
It gives more free usefull RAM for tiny esp8266 (32K free pure memory only !)
2) Less WrongNamedCallers in a bullshits code
By the way how to free memory from unused imports, classes, functions?
Relative post was here, but no sucsess with it.
viewtopic.php?f=2&t=4893&p=28115
kevinkk525
Post by kevinkk525 » Mon Feb 24, 2020 5:40 pm
Kevin Köck
