Isses getting Oled to work properly
MicroNinja
Post by MicroNinja » Sat Feb 22, 2020 9:38 am
I have trouble getting my Oled display to work properly.
In my code you can see i2c.scan(). That is just printing an empty list.
And the program is crashing out with OSError: [Errno 110] ETIMEDOUT.
I am a bit stuck to where I can debug and find out what's wrong? Any ideas?
import ssd1306
# Sanity check blink on board led Default 2
LED_PIN = 2 # On board led
led = Pin(LED_PIN, Pin.OUT)
def blink(times=2):
  for i in range(times):
      led.off()
      time.sleep(0.25)
      led.on()
      time.sleep(0.25)
blink()
i2c = I2C(scl=Pin(5), sda=Pin(4))
i2c.scan() # Print empty list
display = ssd1306.SSD1306_I2C(64, 48, i2c)
display.fill(0)
temp = "Boot2"
display.text(temp,10,10)
display.show()
time.sleep(2)
i = 0
    i+=1
    display.fill(0)
    display.text("{}".format(i),10,10)
    display.show()
    print(i)
    time.sleep(1)
Re: Isses getting Oled to work properly
Post by Roberthh » Sat Feb 22, 2020 9:41 am
If you get an empty list, then the wiring is wrong. Either sda and scl have to be swapped, or the pull-up resistors are missing, or you forgot to connect then GND cable.
MicroNinja
Post by MicroNinja » Sat Feb 22, 2020 9:52 am
Thank you!
I will double check the wiring. I might have moved it around then. I did get it to work before. But whenever I pulled the usb cable out of the wemos something seemed to be chached? or someting. I did not work when I ran script from file using ampy (ampy run <path to script>). To solve that I had to reinstatement the oled in the repl like with just this bit of code:..
After that the oled worked from script again. Any idea why that would be?
display.fill(0)
temp = "Boot2"
display.show()
MicroNinja
Post by MicroNinja » Sat Feb 22, 2020 3:17 pm
Turns out nothing was wrong with wiring or code. I seem to have a faulty unit that just sometimes work. I had another one and that work fine everytime. Annoying when you spend so much time on it :( Oh well
