pack.calcsize('1b1I') = 1+4=8 !?
VladVons
Post by VladVons » Tue Mar 03, 2020 6:09 am
    # size of byte is 1
    print(struct.calcsize('1b'))
    1
    # size of integer is 4
    print(struct.calcsize('1I'))
    4
    # size of byte + integer should be 5, but got 8
    print(struct.calcsize('1b1I'))
    8
Re: pack.calcsize('1b1I') = 1+4=8 !?
Post by jimmo » Tue Mar 03, 2020 6:19 am
Please see https://docs.python.org/3/library/struc ... -alignment
Your example is the same as using the @ specifier, which means "native" alignment, hence it works like a regular C struct, where each member will be aligned.
Use the < or > specifier (which you should do anyway to be clear about which endianness you're using)
print(struct.calcsize('<1b1I'))
5
VladVons
Post by VladVons » Tue Mar 03, 2020 6:22 am
oh yep, thanks!
