How to connect WiFi with certain channel?
VladVons
Post by VladVons » Sun Mar 15, 2020 12:54 pm
to speed up WiFi connection router should receive from ESP:
static IP, bssid, channel number
1) How to get from successful WiFi connection following data?
- channel number
- bssid
2) How to connect WiFi with certain channel number?
connect() has no such parameter
Re: How to connect WiFi with certain channel?
Post by jimmo » Mon Mar 16, 2020 3:04 am
I don't believe this is possible on the ESP8266 -- the config structure that MicroPython passes to the underlying WiFi APIs has no way to specify the channel.
Edit: Actually this is possible. You could implement this quite easily in ports/esp8266/modnetwork.c:
STATIC mp_obj_t esp_connect(size_t n_args, const mp_obj_t *pos_args, mp_map_t *kw_args) {
Add a channel kwarg, then you can add a call to wifi_set_channel(channel);
Post by jimmo » Mon Mar 16, 2020 3:36 am
See https://github.com/esp8266/Arduino/blob ... A.cpp#L127 for a reference of how to use these APIs.
