I am having issues running the following script for a longer period of time.
It is a nodemcu esp8266
#!/usr/bin/env python3
from time import sleep
import urequests
import json
wifiap = network.WLAN(network.AP_IF)
wifiap.active(False)
routercon = network.WLAN(network.STA_IF)
routercon.active(True)
routercon.ifconfig(('10.0.0.128','255.255.255.0','10.0.0.138','10.0.0.138'))
routercon.connect('mywifi', '123')
while not routercon.isconnected():
pass
posturl=('http://10.0.0.156:23102/rest/v2/send')
adc = machine.ADC(0)
gc.enable()
value = adc.read()
if value < 200:
message = {'username': 'test', 'message': value, 'chatid': 'test', 'password': 'test', 'notifyself': 'false'}
r = urequests.post(posturl, data=json.dumps(message).encode())
r.close()
gc.collect()
sleep(1)
File "/usr/local/bin/ampy", line 11, in <module>
sys.exit(cli())
File "/usr/local/lib/python3.6/dist-packages/click/core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.6/dist-packages/click/core.py", line 1137, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.6/dist-packages/click/core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.6/dist-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/ampy/cli.py", line 337, in run
output = board_files.run(local_file, not no_output)
File "/usr/local/lib/python3.6/dist-packages/ampy/files.py", line 303, in run
out = self._pyboard.execfile(filename)
File "/usr/local/lib/python3.6/dist-packages/ampy/pyboard.py", line 273, in execfile
return self.exec_(pyfile)
File "/usr/local/lib/python3.6/dist-packages/ampy/pyboard.py", line 267, in exec_
raise PyboardError('exception', ret, ret_err)
ampy.pyboard.PyboardError: ('exception', b'', b'Traceback (most recent call last):\r\n File "<stdin>", line 28, in <module>\r\n File "urequests.py", line 152, in post\r\n File "urequests.py", line 89, in request\r\nOSError: [Errno 103] ECONNABORTED\r\n')
I tried to play around with the garbage collection but it didn't help.
Any ideas?
Thanks,
BR
