D1 Mini & VS1053b
D1 Mini & VS1053b
Hi folks,
my name is Chris and i try to get some sound out of an esp8266 with vs1053b.
I wired it as i think is correct ......so my code runs, but when i read from SPI, i always get FFFFFFFF. As well as it doesn't play a tone.
I tried to port the vs1053 adafruit circuitpy module (https://github.com/adafruit/Adafruit_Ci ... hon_VS1053).
What am i doing wrong?
init is:
self._xcs = Pin(xcs, Pin.OUT)
self._xdcs = Pin(xdcs, Pin.OUT)
self._dreq = Pin(dreq, Pin.IN)
self._spi = SPI(1, baudrate=_COMMAND_BAUDRATE, polarity=0, phase=0 )
reading :
self._SCI_SPI_BUFFER[0] = _VS1053_SCI_READ
self._SCI_SPI_BUFFER[1] = address & 0xFF
self._spi.init(baudrate=_COMMAND_BAUDRATE)
self._spi.write(self._SCI_SPI_BUFFER)
self._spi.readinto(self._SCI_SPI_BUFFER)
Regards,
Chris
init is:
reading :
Regards,
Chris
Re: D1 Mini & VS1053b
I don't see anywhere in your code where you're using the self._xcs pin (which I assume is your chip select). I'd expect to see it being set low before the operation, then high afterwards. (Chip select is generally active low).
(Similarly with _xdcs (not sure what that is? is it a Data/Command pin?)
Ok...you're right....i left out that part:
self._xdcs(0)
self._xcs(0)
i tried that in all variants.......just before and after operations.
oh...according to https://cdn.sparkfun.com/datasheets/Dev ... S1053B.pdf xdcs is "Data chip select / byte sync" .
Or in the SDI description it's "data interface chip select"....
self._xdcs(0)
self._xcs(0)
So nobody can help me? Or give me a hint?
Please
Please
Could you post the latest version of your code. I'm not quite sure I followed what you said about setting cs to zero (do you also set it back to 1 again after the operation?).
@SIGTERM You might like to read this.
tl;dr According to Adafruit's own code comments their driver doesn't actually work.
this code works on esp32 micropython : https://github.com/urish/vs1053-circuitpython with little modification
That is interesting, it looks like he's done a good job of speeding up the response to the DREQ line. I wonder why Adafruit haven't taken this up?
Since DREQ is a physical pin it would seem to offer the possibility of using an IRQ. From a quick look at the datasheet the VS1053b has a 2KiB FIFO buffer. If an MP3 has a bitrate of 128Kbps that's 16KiB/s so the buffer holds 125ms of sound. On the face of it MicroPython on an ESP8266 should be able to keep up with this easily. Am I missing something here? I wonder where the problem is.
i wonder is there any replace function for "spi.try_lock()" and "spi.unlock()" in mocropython, i removed these line form micropython code @ https://github.com/urish/vs1053-circuitpython and change the gpio acording to micropython - i could run internet radio . but wand to find the way to replace spi lock and unlock.
Yes. I have ported code from Adafruit replacing their bus classes with straight I2C or SPI, for example this RA8875 driver. The object of the bus device code is simplify sharing the bus between multiple devices. They have a different approach to coding, prioritising ease of use by complete beginners over performance. It can make their code quite hard to follow.
The general MicroPython approach is rather the converse, prioritising small code size, performance and readability, potentially at the cost of assuming some degree of experience on the part of users.
