Approximately 60% into the downloaded, I receive the following text from the ESP8266:
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with access-point, channel 11
dhcp client start...
ip:192.168.xxx.xxx,mask:255.255.240.0,gw:192.168.xxx.xxx
pm open,type:2 0
The board is flashed with firmware I have built from the 1.12 source. I am using uPyLoader to transfer the file to the ESP8266.
The last version of the firmware (1.10) I downloaded and flashed did not have these messages from the RTOS.
Is there a make flag or environment variable I can set to eliminate these messages from the RTOS?
