If I flash v1.12 stable onto a 4M D1 mini and import gc, gc.mem_free() how much should I have? It responds 32,944 which is ~33k available? Where's the other 3.5m? Also tried to flash with flash_size=4MB but same result (auto detected 4MB too).
Thanks,
PsuFan
How much memory should a ESP8266 D1 Mini have available?
Re: How much memory should a ESP8266 D1 Mini have available?
There is a difference between Flash memory and the memory you have available for your programs (RAM).
The 33K available is memory you have for variables and running MicroPython.
The 4MB of flash memory is split between storing Micropython itself and the rest is used as the file system for storing your scripts and files.
Hope that helps.
Hope that helps.
Yeah thanks. Is the 33K normal? Is there a way to configure what is available to memory and what is available to storage?
Yes: if you buy an esp8266 you get a tad over 30KB of RAM available, if you buy an esp32 you get a tad over 110KB of RAM available
So the configuration happens in the shopping cart
Seriously, maybe this is helpful? https://deepbluembedded.com/microcontro ... -tutorial/ It's obviously not about the esp32 or micropython, but seems to touch the right topics.
LOL, thanks. I do have some ESP32 on the way. I saw they were using them to drive a ili9341 TFT. It does work pretty well with a 8266 until I tried to send all or even half the screen at the same time lol. I think it's 153K, so even the 32 can't send the whole thing.
Depending on what you're doing, might be tough to beat https://www.makerfabs.com/makepython-es ... r-lcd.html w/the wrover option. It's $14.99 + shipping (at least in the US). Clearly significantly more costly than esp8266 but I overcame my ram issues w/it.
Color oled as well.
I am fiddling w/using the esp32-cam also w/the same amount of ram, but I am not quite successful using gpio pins.
I'm trying the Esp32-Cam CH340 soon, if interested in my results.
Color oled as well.
