machine.reset is not working properly ?
zmaier
Post by zmaier » Mon May 11, 2020 5:34 am
i am using a Wemos D1 Mini and i have troubles using machine.reset()
Here is the code of main.py :
import sys
from uio import StringIO
    import run.mpy
except KeyboardInterrupt:
    sys.exit()
except Exception as e:
    s=StringIO(); sys.print_exception(e, s)
    x=s.getvalue()
    payload="system exception=\"{1}\"".format(e)
    temp=open("error.txt","w")
    temp.write(payload)
    temp.write(x)
    temp.close()
    machine.reset()
My intention is, if a error occurs in run.mpy the error should be logged in the file error.txt and the Wemos should restart.
The Problem now, the error is logged correct, but the esp is not restarting.
I got the micropyhton-shell, it seems, that the boot.py and main.py is not excecuted?
Doing Strg+D everthing is ok, donig a hardreset with the reset button, also everthing is working as expected.
Yes, i could catch the error within the run.mpy but, for debubing reasons i would like to do it that why :)
Any ideas why?
kevinkk525
Re: machine.reset is not working properly ?
Post by kevinkk525 » Mon May 11, 2020 5:42 am
Well I never tried it that way.
I always catch errors in main.py and my machine.reset() has always worked reliable there. even in my watchdog implementation.
Kevin Köck
tve
Post by tve » Mon May 11, 2020 7:13 am
This doesn't help you with your reset problem, but I believe you could avoid the StringIO by doing sys.print_exception(e, temp).
Also, `with open("error.txt", "w") as temp:` is a nicer way to write the file I/O...
WRT reset, is the esp8266 going through a full system reset?
