Get large log files from sd card over wifi?
JonRob
Post by JonRob » Thu Jun 11, 2020 11:44 pm
I searched but no luck, How could I download large files from over the wifi? over 20MB file sizes.
I tried an FTP script but it stalls on files this big. Any ideas?
cgglzpy
Re: Get large log files from sd card over wifi?
Post by cgglzpy » Fri Jun 12, 2020 12:26 pm
Hi JonRob,
You could try upydev, just follow the instructions in the README
and then use sync command , e.g.:
$ upydev sync -f logACC_26_6_2019_0_18_42.txt -s sd
Note:
  • 1) The SD card should be mounted as 'sd'
  • 2) 20 MB is large so expect at least 2-3 minutes with ideally conditions, or even double with the esp8266
I will do a test with the esp32 and let you know the times exactly.
bitninja
Post by bitninja » Fri Jun 12, 2020 2:44 pm
I use...
https://github.com/robert-hh/FTP-Server ... 2-and-PYBD
and am able to transfer files from the file system AND the sdcard much larger than 20MB.
JonRob
Post by JonRob » Mon Jun 15, 2020 7:58 pm
I use...
This works, thanks!
