Permission denied on Make for xtensa-lx106-elf-gcc
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 9:48 am
as a newbie to cross compilation I am trying to compile a driver written in C for use on an XBee3 board on which I previously successfully ran a ESP8266 library.
I am following this guide/example: https://docs.micropython.org/en/latest ... tmod.html
The example compiles fine for my x64 architecture. However trying to compile for xtensa gives me "Permission denied":
 make: xtensa-lx106-elf-gcc: Permission denied
I installed xtensa-lx106-elf-gcc, it sits in /opt and I changed owner from root to myself, chmod-ing also doesn't help. OS is arch linux.
Any suggestions? Thank you!
davef
Re: Permission denied on Make for xtensa-lx106-elf-gcc
Post by davef » Fri Aug 21, 2020 10:18 am
Did you try:
sudo make
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 11:37 am
sure did
Post by Roberthh » Fri Aug 21, 2020 1:04 pm
can you verify, that xtensa-lx106-gcc has the x flag set as being executable?
Post by pythoncoder » Fri Aug 21, 2020 1:13 pm
Also check permissions for its parent directories.
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 1:27 pm
yes:
 drwxr-xr-x  8 andre users 4096 20. Aug 13:33 xtensa-lx106-elf-gcc
(and all the same downwards from there)
but now seeing you, Robert, here, I might as well tell you the device I'm going to use on the XBee3 via I2C: Its from the family of "DLV Series Low Voltage Digital Pressure Sensors" and the only library I could find is this one: https://github.com/jeremycole/AllSensors_DLV
I've successfully used your BME280 library (thank you!), but we also need a higher pressure sensor (up to 2000 mbar).
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 1:30 pm
@pythoncoder: well, the parent directory is /opt, guess I shouldn't fiddle with that. But sudo didn't work either.
Post by Roberthh » Fri Aug 21, 2020 1:52 pm
The xtensa-lx106-elf-gcc looks strange, since it has the d-flag set, meaning it's a directory. On my system, it is an executable, residing in a tree of ..../esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc together with other binaries like the loader.... . So please check the structure of the file system.
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 2:57 pm
That was it. I had found another xtensa-lx106-elf-gcc package for arch and was trying to use it (https://aur.archlinux.org/packages/xten ... f-gcc-bin/). Works with esp-open-sdk. Thank you.
lambu0815
Post by lambu0815 » Fri Aug 21, 2020 3:11 pm
However the code will not run on XBee3. "incompatible .mpy file". Too bad.
