Repl doesn't work ESP-01
ElementaLucky
Post by ElementaLucky » Fri Aug 21, 2020 4:54 pm
Hi,everyone.I'm new on forum.I flashing micropython on ESP-01,the flash is good but when i open putty and conect to ESP-01,repl show black screen.I erased the firmware before flash the new micropython flash.What could be the problem?
Re: Repl doesn't work ESP-01
Post by Roberthh » Fri Aug 21, 2020 5:11 pm
With putty, did you set flow control to 'None'?
What flash size has your module? The ESP01 boards used to have 512kByte Flash. For those you have to use that specific firmware image form the daily builds.
ElementaLucky
Post by ElementaLucky » Fri Aug 21, 2020 5:28 pm
Hi Robbert.The firmware flash is 512kb version and putty,yes,i set none in flow control.Thanks you to help me.
Post by Roberthh » Fri Aug 21, 2020 6:31 pm
You may try other -fm options when uploading the firmware. The default is -fm dio. Sometimes -fm dout works. But for my ESP-01 I used the default mode.
ElementaLucky
Post by ElementaLucky » Fri Aug 21, 2020 8:21 pm
I try with dout option,but nothing happen.I have 2 modules and test with other but nothing change.I used NODEMCU Pyflasher.
