This seems to be a common issue but I've tried all the suggestions I could find with no solution
I've gone through a few posts about how to fix this issue but no luck.
Flash goes ok and then I can access the REPL, but the device will restart every few seconds showing:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 30768, room 16
tail 0
chksum 0xc4
load 0x3ffe8000, len 1024, room 8
tail 8
chksum 0xd8
load 0x3ffe8400, len 1080, room 0
tail 8
chksum 0xc4
csum 0xc4
Linux:
- screen /dev/ttyUSB0 -f 115200
- thonny
- putty with control flow disabled
- ESPlorer
- 2 NodeMCUs with the ESP8266MOD chip
- 1 D1 Mini with the ESP8266MOD chip
Method of Flashing:
$ esptool.py --port /dev/ttyUSB0 erase_flash
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 48:3f:da:56:7d:a9
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 8.0s
Hard resetting via RTS pin...
$ esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash --flash_size=detect -fm dio 0 esp8266-20200911-v1.13.bin
esptool.py v2.8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0240
Compressed 638928 bytes to 419659...
Wrote 638928 bytes (419659 compressed) at 0x00000000 in 37.0 seconds (effective 138.1 kbit/s)...
Hash of data verified.
Leaving...
Thanks for any additional suggestions
