External interrupts, different behavior between Arduino and MicroPython
Posted: Sun Oct 18, 2020 5:11 pm
I use ESP8266 NodeMcu V3 board and built circuit similar to this one https://i.ytimg.com/vi/eFeOSiL-IBQ/hqdefault.jpg
At the beginning I tried to count "frequency"
In code bellow i expected -/+ 100 ticks per second (50Hz), but I got 200-208.
I created similar C++ code and the same circuit works as expected.
Why is that?
Any suggestions?
import micropython
counter = 0
def handler(pin):
global counter
counter += 1
pin = machine.Pin(12, machine.Pin.IN, machine.Pin.PULL_UP)
pin.irq(trigger=Pin.IRQ_RISING, handler=handler)
while (True):
time.sleep_ms(1000)
print(counter)
counter = 0
int counter = 0;
void setup() {
Serial.begin(115200);
pinMode(12, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(12), zcDetect, RISING);
void loop() {
delay(1000);
Serial.println(counter);
counter = 0;
ICACHE_RAM_ATTR void zcDetect() {
counter += 1;
Any suggestions?
