I am new to the MicroPython and maybe I missing key concepts. I erased flashed on my NodeMCU (2MB flash) and installed the lastest firmware. https://micropython.org/resources/firmw ... -v1.13.bin
I am able to communicate with it over serial port. I can see list of modules but the most important ones like 'esp', 'network', 'machine' are not just there. Are they need to be uploaded manually? How? Note, I am using Windows 10 and the mass storage is not showing up for any upload :/
There is a list of modules I can see.
>>> help('modules')
Please wait a moment while I gather a list of all available modules...
C:\Users\mail\AppData\Local\Mu\pkgs\IPython\kernel\__init__.py:13: ShimWarning: The `IPython.kernel` package has been deprecated since IPython 4.0.You should import from ipykernel or jupyter_client instead.
"You should import from ipykernel or jupyter_client instead.", ShimWarning)
pygame 1.9.6
Hello from the pygame community. https://www.pygame.org/contribute.html
C:\Users\mail\AppData\Local\Mu\Python\python36.zip\pkgutil.py:107: VisibleDeprecationWarning: zmq.eventloop.minitornado is deprecated in pyzmq 14.0 and will be removed.
Install tornado itself to use zmq with the tornado IOLoop.
IPython brain_builtin_inference gpiozerocli qtconsole
PIL brain_collections guizero queue
PyQt5 brain_crypt gzip quopri
__future__ brain_curses hashlib random
_ast brain_dataclasses heapq re
_asyncio brain_dateutil hmac reprlib
_bisect brain_fstrings html requests
_blake2 brain_functools http rlcompleter
_bootlocale brain_gi idna rmagic
_bz2 brain_hashlib imaplib runpy
_codecs brain_http imghdr sched
_codecs_cn brain_io imp secrets
_codecs_hk brain_mechanize importlib select
_codecs_iso2022 brain_multiprocessing inspect selectors
_codecs_jp brain_namedtuple_enum io semver
_codecs_kr brain_nose ipaddress serial
_codecs_tw brain_numpy_core_fromnumeric ipykernel setuptools
_collections brain_numpy_core_function_base ipykernel_launcher shelve
_collections_abc brain_numpy_core_multiarray ipython_genutils shlex
_compat_pickle brain_numpy_core_numeric isort shutil
_compression brain_numpy_core_numerictypes itertools signal
_csv brain_numpy_core_umath jedi simplegeneric
_ctypes brain_numpy_ndarray json sipbuild
_datetime brain_numpy_random_mtrand jupyter site
_decimal brain_numpy_utils jupyter_client six
_dummy_thread brain_pkg_resources jupyter_core smtpd
_elementtree brain_pytest keyword smtplib
_findvs brain_qt kiwisolver sndhdr
_functools brain_random lazy_object_proxy socket
_hashlib brain_re lib2to3 socketserver
_heapq brain_six linecache sqlite3
_imp brain_ssl locale sre_compile
_io brain_subprocess logging sre_constants
_json brain_threading lzma sre_parse
_locale brain_typing macpath ssl
_lsprof brain_uuid macurl2path stat
_lzma builtins mailbox statistics
_markupbase button mailcap storemagic
_md5 bz2 marshal string
_msi cProfile math stringprep
_multibytecodec calendar matplotlib struct
_multiprocessing certifi mccabe subprocess
_opcode cgi mimetypes sunau
_operator cgitb mmap symbol
_osx_support chardet modulefinder sympyprinting
_overlapped chunk msilib symtable
_pickle cmath msvcrt sys
_pydecimal cmd mu sysconfig
_pyio code multiprocessing tabnanny
_random codecs netrc tarfile
_sha1 codeop nntplib telnetlib
_sha256 collections nt tempfile
_sha3 colorsys ntpath tests
_sha512 colorzero nturl2path textwrap
_signal compileall nudatus this
_sitebuiltins concurrent numbers threading
_socket configparser numpy time
_sqlite3 contextlib opcode timeit
_sre copy operator tkinter
_ssl copyreg optparse token
_stat crypt os tokenize
_string csv parser tornado
_strptime ctypes parso trace
_struct curses pathlib traceback
_symtable cycler pdb tracemalloc
_thread cythonmagic pexpect traitlets
_threading_local datetime pgzero tty
_tkinter dateutil pickle turtle
_tracemalloc dbm pickleshare typed_ast
_warnings decimal pickletools types
_weakref decorator pigpio typing
_weakrefset difflib pipes unicodedata
_winapi dis pkg_resources unittest
abc distutils pkgutil urllib
aifc doctest platform urllib3
antigravity dummy_threading plistlib uu
appdirs easy_install poplib uuid
argparse email posixpath warnings
array encodings pprint wave
ast enum profile wcwidth
astroid errno prompt_toolkit weakref
asynchat faulthandler pstats webbrowser
asyncio filecmp pty winreg
asyncore fileinput ptyprocess winsound
atexit fnmatch py_compile wrapt
audioop formatter pyclbr wsgiref
autoreload fractions pycodestyle xdrlib
backcall ftplib pydoc xml
base64 functools pyexpat xmlrpc
bdb gc pyflakes xxsubtype
binascii genericpath pygame zipapp
binhex getopt pygments zipfile
bisect getpass pylab zipimport
boot gettext pylint zlib
brain_argparse glob pyparsing zmq
brain_attrs gpiozero pytz
Enter any module name to get more help. Or, type "modules spam" to search
for modules whose name or summary contain the string "spam".
