How do I create a websocket at such an address: 192.168.5.49:80/Chat
The only thing that succeeds for me is: 192.168.5:80
I can do it in c, and javascript.
How to Websocket sub address?
Yes Frida is my watchdog!
Re: How to Websocket sub address?
I'm not quite sure what you're asking... "192.168.5:80" is not a valid ip addr & port.
What have you tried so far?
Are you trying to use a static IP address? Or is the issue that you want to use a specific port? Or more a general question on how to run a websocket server?
I wrote: The only thing that succeeds for me is: 192.168.5:80
It should have been '192.168.5.49:80'
I have set up a web socket server at a local address '192.168.5.49', which is accessed via port '80', and the path '/ Chat'.
It all works fine with javascript, but after I changed the router, it takes 20 minutes to get my clients to connect to the router.
If I load micropython on the same device, I get hooked up right away.
The same is true of a c program.
It would be easier to do in micropython than in c if I can access my path.
In c I have a hole through to my path, but there is a lot of programming left for the last part to run.
If there is no option in micropython, I have to fix it in c.
- pic1.png (309.26 KiB) Viewed 360 times
- pic2.png (191.13 KiB) Viewed 360 times
- pic3.png (179.21 KiB) Viewed 360 times
