high value reading DHT22 temperature
dlnl
Post by dlnl » Sun Nov 22, 2020 12:01 pm
I'm trying to read my DHT22 sensor (I think it's a DHT22) on my nodemcu ESP8266 board with micropython 1.13.
I use the following example code for DHT22:
    import dht
    d = dht.DHT22(machine.Pin(4))
    d.measure()
    print(d.temperature()) # eg. 23.6 (°C)
    print(d.humidity())    # eg. 41.3 (% RH)
I seem to get a response for the temperature in the range of 500-600.
However, when I use the DHT11 like this:
d = dht.DHT11(machine.Pin(4))
I get a more sensible response like 22 (degrees C).
Does this mean I'm probably working with a DHT11 sensor, or do I need to apply some more formatting on the DHT22 value received to make more sense of the output?
Thank you in advance!
Best regards,
Re: high value reading DHT22 temperature
Post by Roberthh » Sun Nov 22, 2020 12:38 pm
The code should work as it is. So if using the DHT11 code returns proper values, you probably have a DHT11 sensor (clone).
What about the humidity?
dlnl
Post by dlnl » Sun Nov 22, 2020 1:04 pm
Yes, with Humidity it's the same. High values when printing d.humidity() for the DHT22, but (seemingly) correct values for DHT11.
So if it should work like the example code, then I will most likely have the dht11 sensor and not the dht22 sensor.
Thanks for the fast reply!
Best regards,
kevinkk525
Post by kevinkk525 » Sun Nov 22, 2020 4:04 pm
It might help to put a sleep of 1 second between measure() and temperature/humidity() because those sensor can take a while. But haven't used one of those in years, they are not very reliable and accurate.
Kevin Köck
