Well, putting the resistors to 3V3 correctly made no change.
If I read the file back on WebREPL I see the current changes but it appears that after doing a hard reset that that is not the file running on the device.
I try re-flashing the firmware or another ESP-01S
ESP-01S GPIO2 problem
Re: ESP-01S GPIO2 problem [solved]
Problem sorted.
Make certain that you are modifying the file that you are actually running on the device ... and not another one with a "similar" file name.
Apologies for wasting your time.
Regards,
Dave
Regards,
Dave
