importing SPi from machine error with wifi
yefj
Post by yefj » Sun Dec 20, 2020 11:25 am
Hello,I have built a code which creates wifi network.
then i tried to simultaniosly send data over SPI and as shown bellow
and it gave me an error of :
File "<stdin>", line 3, in <module>
NameError: name 'machine' isn't defined
But when i did SPI alone ,It sent SPI just fine.
Why SPI and wifi are conflicting on thonny micropython?
Thanks.
from machine import Pin,SPI
import usocket as socket
spi = machine.SPI(1, baudrate=1000000, polarity=0, phase=0)
spi.write(b'1234')
ap_if = network.WLAN(network.AP_IF)
ssid = 'Sensor network3'
password = '123456789'
ap_if.active(True)
ap_if.config(essid=ssid, password=password)
s=socket.socket(socket.AF_INET,socket.SOCK_STREAM)
s.bind(('',80))
s.listen(5)
    conn, addre=s.accept()
    request=conn.recv(1024)
    request='<p style="color:red"><u><h1>The temperature is:</u></p>'
    request2=str(12.9)
    response='gyhkjgku'
    conn.send('HTTP/1.1 200 OK\n')
    conn.send('Content-type: text/html\n')
    conn.send('Connection: close\n\n')
    conn.sendall(request)
    conn.sendall(request2)
    conn.close()
Re: importing SPi from machine error with wifi
Post by Roberthh » Sun Dec 20, 2020 11:39 am
That#s because you did not import machine, but SPI from machine. So the line should read:
spi = SPI(1, baudrate=1000000, polarity=0, phase=0)
That's the way it works in Python.
