esp8266 resetting while using MQTT
jsmith
Post by jsmith » Sun Jan 10, 2021 5:56 pm
This is my first post. Thank you for this great resource!
I have a esp8266 board that keeps resetting on me. It has a couple sensors attached, and I'm reporting their values via mqtt. I had it running very reliably indoors (next to my wireless router). I've now moved it outdoors near the limit of my wifi coverage and it keeps resetting every 30 seconds to five minutes. I'm using the umqtt.robust library. I also tried rolling my own robust class by wrapping all the mqtt related calls in try/except blocks (which now looking at the robust code is exactly what it's doing). This worked great indoors as I was able to unplug my router, disconnect the MQTT server from the network, etc and my client always recovered. However, now that wifi is weak, the board keeps spontaneously resetting.
Does anyone have any suggestions? Thanks!
Re: esp8266 resetting while using MQTT
Post by Roberthh » Sun Jan 10, 2021 7:05 pm
You should check the power supply. At poor reception conditions the send level has to be higher, which consumes more current.
