Unable to read/write to memory mcp23017
pequnio3
Post by pequnio3 » Mon Feb 15, 2021 12:15 am
I have a Feather Huzzah esp8266 connected to a cqrobot mcp23017 board. I am attempting to read/write the memory from the mcp, however it returns an error.
i2c = I2C(scl=Pin(5), sda=Pin(4))
i2c.scan()
# output:
# [37]
i2c.readfrom_mem(37,0x00,1)
# Error
# Traceback (most recent call last):
# File "<stdin>", line 1, in <module>
# OSError: [Errno 19] ENODEV
It also fails when I attempt a writeto_mem operation. Any ideas what is causing this?
Thank you!
Re: Unable to read/write to memory mcp23017
Post by jimmo » Mon Feb 15, 2021 3:24 am
The fact that you see it in the scan indicates that the pull-ups etc are correct, and the device is responding.
Perhaps it needs some configuration before you can access that register. Have you seen https://github.com/mcauser/micropython-mcp23017
pequnio3
Post by pequnio3 » Mon Feb 15, 2021 10:42 pm
Thats the library I was attempting to use with it however, just trying to initialize it got me the shown error, and I was able to trace it back to that readfrom_mem command. Could the device be malfunctioning in someway? I am using this dev board for it:
http://www.cqrobot.wiki/index.php/MCP23 ... sion_Board
