mu not running code but website download works
Questions and discussion about running MicroPython on a micro:bit board.
Target audience: MicroPython users with a micro:bit.
sooseeg
Postby sooseeg » Fri Feb 17, 2017 12:17 pm
Hi, I'm using mu to play around with a Microbit and I'm finding that mu is acting up.
Using some code from the microbit-micropython docs I'm trying to display ALL_CLOCKS. When I flash the code from mu I get an error: "Type error function does nte??????"
But if I download exactly the same code from the microbit website and drag it onto the Microbit, it works!
This also happens with the simple program to use pin0 to display a happy face when touched - won't run when coded/flashed from mu but runs fine when coded/downloaded from website.
I've checked & checked my code, I've even copied/pasted from mu into microbit website & it all works fine. Is there some issue with mu? I'm a bit stuck as I can't find an error with my code.
Help please!
Sue
sooseeg
Re: mu not running code but website download works
Postby sooseeg » Fri Feb 17, 2017 3:35 pm
Got this sorted by downloading latest version of mu - all fine now. :roll:
Who is online
Users browsing this forum: No registered users and 2 guests
