I'm new to the Microbit but have some experience with microcontrollers (PIC and Arduino using C) and I'm just learning Python.
I would like to know how I can use an ST VL5310x Time of Flight sensor with my Microbit. The VL6180X sensor is mentioned here
viewtopic.php?t=2919
and there is a python file mentioned here for the VL6180X
viewtopic.php?f=14&t=1902
How could this file be adapted and used with the MicroBit? Is it possible to make changes to the hexadecimal numbers(addresses?) in this file by referring to the datasheet for the VL5310X? What do I have to do then to get this to work?How would a python file be included in the source code in mu for instance?
I hope someone can help? Thanks.
David.
Using a VL5310x ToF sensor on the micro:bit
Re: Using a VL5310x ToF sensor on the micro:bit
Unfortunately it's a little bit more complex than just changing a couple of numbers. The VL5310x has a lot of registers that have to be initialized to correct values for it to work properly, and they are different than with VL6180x. I started writing a driver for it, based on Pololu code here https://github.com/pololu/vl53l0x-arduino but I didn't get very far yet.
Having just implemented a library for this sensor for MicroPython I must say that I don't think the Micro:bit will ever be able to properly drive that sensor. The amount of code required to set all the magical registers to their proper values is simply too large. I would recommend using an analog distance sensor, such as the ones produced by SHARP -- they are super-easy to use.
Hello All,
Is there any one who was able to run the VL53L0X on the micro:bit. I'm able to run the VL53L0X on the ESP32 and the STM32 Nucleo WB55 but I could not make it work on the micro:bit
Please share with us the tips if you were able to run it.
Julien
Julien
good question! Since micro:bit V2 offers much more RAM and Flash this could be possible. I also would like to have a driver for this!
