I want to take a numeric value such as -9.472, convert it to a string (OK, I can do that), and then convert the string into a list:
my_list, which equals [ "-", "9", ".", and so on. The individual characters will get used on a display. I found the statement below in the online documentation:
String.split(separator: str, limit: number): List[str]
But the "explanation" doesn't include a concrete example of how to use this statement. Can someone help, please? Thanks.
Also, I could not find information about how to interpret the statement above. It might help to have an introduction to the docs that describes this syntax. Cheers. --Jon
Split a string into a list--help needed
Re: Split a string into a list--help needed
You don't really need to split the string into a list. You can just dereference the characters from the string directly.
>>> s = '-9.4732'
>>> s[0]
>>> s[1]
'9'
>>> s[2]
>>> len(s)
7
>>> for ch in s:
... print(ch)
9
4
7
3
2
>>> for idx in range(len(s)):
... print(s[idx])
9
4
7
3
2
If you really want a list my_list mad from a string str, you can simply write:
my_list = list(str)
But, as Dave said, direct dereferencing the str is the shortcut you most probably should take.
my_list = list(str)
Fantastic guys! Didn't know that was possible. I greatly appreciate your help. Happy 4th of July. --Jon
