Connect RGB LED strip to Microbit
Questions and discussion about running MicroPython on a micro:bit board.
Target audience: MicroPython users with a micro:bit.
vmcduarte
Post by vmcduarte » Sat Dec 18, 2021 4:40 pm
Hello
I have a 4 pin RGB strip (picture in attachment)
How do I connect it to Microbit board? I mean which pin in in the strip is connected to each pin in the board?
And what pins combination will generate each color?
Thank you!
scruss
Re: Connect RGB LED strip to Microbit
Post by scruss » Sat Dec 18, 2021 9:23 pm
This is an analogue LED strip. You won't be able to drive it directly from a micro:bit, but you'll need 3 N-Channel MOSFETs plus an external power supply and use three digital output lines to PWM the RGB channels to make different colours.
A rough guide to what you need to use: Overview | RGB LED Strips | Adafruit Learning System
