MU-5 will crash and delete all source code
BobH
Post by BobH » Wed Jan 18, 2017 3:46 pm
If you try to display a degree sign on the MicroBit, it will crash MU and delete all source from the program source file e.g.:
from microbit import *
display.scroll("°")
As soon as you try to save it, MU5 crashes - If you had edited a previous file, it will empty it, then close it.
BobH
Re: MU-5 will crash and delete all source code
Post by deshipu » Wed Jan 18, 2017 6:44 pm
I think you found a bug, you should definitely report it!
BobH
Post by BobH » Thu Jan 19, 2017 7:11 am
The problem is not just that it is an un recognisable character for the display command, as I am trying to write "°" to a 16 x 2 LCD screen. When I lost 200 lines of code, I wasn't too happy. :x
BobH
Post by BobH » Thu Jan 19, 2017 7:50 am
How do I report this and to who. I opened a Github acct, but it is beyond me as to how it works. README, Forks, Commits and publish. Its a bit too tech for a schoolboy.http://forum.micropython.org/posting.ph ... =17&t=2920#
Post by deshipu » Thu Jan 19, 2017 10:07 am
Please use this link: https://github.com/mu-editor/mu/issues/new
Describe your issue in detail, don't forget to provide the exact version your are using, your operating system, and anything else you think might be relevant.
ntoll
Post by ntoll » Thu Jan 19, 2017 1:00 pm
