help adding string module to mu or any other ide
JKD
Post by JKD » Mon Mar 27, 2017 1:14 am
Hi
New member & new micro Python user here
I am developing a microbit project which needs the zfill function from the string module.
How do I add this module to mu or any other IDE?
Any help would be appreciated
Re: help adding string module to mu or any other ide
Post by deshipu » Mon Mar 27, 2017 7:37 am
Can't you just implement that function in Python yourself?
Post by Roberthh » Mon Mar 27, 2017 12:53 pm
Just in case you can't, here is a try:
def zfill(s, width):
    if len(s) < width:
        return ("0" * (width - len(s))) + s
        return s
The difference to the built-in method: instead of
s.zfill(width)
you have to call
zfill(s, width)
And yes, this function may consume more heap space than a built-in method.
JKD
Post by JKD » Mon Mar 27, 2017 3:46 pm
Many thanks to you both
Robert I am certainly NOT able to , am getting back into a little programming after a long break. Last programming I did was on a commodore pet & zx81!!!
Can't wait to get home and try your code , looks like it will do just what I need
Regards
JKD
Post by pythoncoder » Tue Mar 28, 2017 7:33 am
An alternative (more efficient) approach is:
	return '{:0>{w}}'.format(s, w=width)
JKD
Post by JKD » Tue Mar 28, 2017 7:43 am
Hi peter
Many thanks
TravisT
Post by TravisT » Tue Apr 04, 2017 3:00 am
My two cents is it would be nice to use zfill the same way as in the standard python library, especially when using micropython unix.
I also know if I am complaining that I should contribute to the project and add it myself :-)
_______________
Travis Travelstead
Post by deshipu » Tue Apr 04, 2017 6:46 am
There is a reason why it's called MicroPython.
Post by pythoncoder » Wed Apr 05, 2017 8:20 am
Indeed. New users are advised to read this https://github.com/micropython/micropyt ... ifferences.
JKD
Post by JKD » Wed Apr 05, 2017 9:17 am
Many thanks to all the kind & helpful people who have helped with advice & code.
Really appreciate all the time & trouble you went to !
Regards
Jason
