Bluetooth Pairing Mode Probem
petergrubercom
Post by petergrubercom » Fri Jun 02, 2017 9:39 am
I cannot get my micro:bit into pairing mode. It shouldn't be that difficult (press and hold A+B, then briefly press the reset button), but noting happens. When I press the reset button, the program is halted, when I release it, it restarts. No pairing mode whatsoever.
Did I make a mistake? Is there a (known) problem with my device?
shaoziyang
Re: Bluetooth Pairing Mode Probem
Post by shaoziyang » Sat Jun 03, 2017 3:59 am
Do you download javascript firmware? App must using this firmware to connect.
Post by deshipu » Sat Jun 03, 2017 4:33 am
MicroPython on the Micro:bit doesn't have bluetooth support, because that requires too much memory.
petergrubercom
Post by petergrubercom » Sat Jun 03, 2017 10:36 am
Thanks for your replies, but the problem is earlier. It is the simple *pairing* of the micro:bit with my iPhone 5s.
rhubarbdog
Post by rhubarbdog » Fri Nov 10, 2017 4:30 pm
You can only get blue tooth working in languages other than micropython.
It's only the initial program and other downloadable images which csn be used to get pairing mode up and running. Simply holding down a and b then pressing reset wont work if you've flashed a program onto the microbit
javargas26
Post by javargas26 » Wed Dec 06, 2017 12:44 am
How can I pear a ESP32 with android using bluetooth?
SpotlightKid
Post by SpotlightKid » Wed Dec 06, 2017 1:08 pm
@javargas26: please post your questions in the appropriate forum sections, and not in an unrelated thread. This section is for discussing MicroPython on the micro:bit, not on the ESP32.
