Installing Mu on Linux
rhubarbdog
Post by rhubarbdog » Sat Nov 11, 2017 9:53 am
Has anyone got a sucess story?
I downloaded the zip from github and un zipped it.
I then typed
pip3 install -r requirements.txt
this nearly worked first time, but i had to use
sudo apt-get install ...
and re-ran pip3 install ... I now have a partially working Mu ide.
Issue 1: file only works if i'm root. If i'm a normal user the following error box pops up. Could not find an attatched micro:bit
Issue 2: repl only works if i'm root, if i'm a normal user the following error box pops up. Cannot connect to device on port /dev/ttyACM0
Issue 3: even as root file and repl may crash Mu
Issue 4: lots of error diagnostics are printed to stdout
When i'm up and running i'll publish a guide for micro:bit and mint/ubuntu/debian linux
Re: Installing Mu on Linux
Post by deshipu » Sat Nov 11, 2017 3:18 pm
Did you follow the instructions at https://codewith.mu/?
rhubarbdog
Post by rhubarbdog » Sat Nov 11, 2017 7:14 pm
I'm always reluctant to install anything that can't be achieved by
I've just tried clicking download for linux and followed instructions to make it executble.
added myself to group dialout logged out and back in for that to take effect.
Running mu as a normal user yielded the following then hung
Logging to /home/phil/.cache/mu/log/mu.log
Running mu as root yeilded the following then hung
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
rhubarbdog
Post by rhubarbdog » Sat Nov 11, 2017 7:18 pm
Now I'm a member of group dialout I can use the file option without being root, 1 partial success
still getting the following output
QApplication: invalid style override passed, ignoring it.
Flashing Python to: /media/phil/MICROBIT/micropython.hex
QXcbConnection: XCB error: 3 (BadWindow), sequence: 4101, resource id: 12689831, major code: 40 (TranslateCoords), minor code: 0
being a member of dialout has allowed me to open the REPL, but my micro:bit isn't executing what i type in
rhubarbdog
Post by rhubarbdog » Sat Nov 11, 2017 7:24 pm
REPL working you have to crash into running code, i was trying after i had pressed button_a to break from the while True:
rhubarbdog
Post by rhubarbdog » Sat Nov 11, 2017 9:14 pm
Instructions that work with linux mint, ubuntu and other debian systems can be found here https://ubuntuforums.org/showthread.php ... st13710070
