what is the clock speed on a microbit
rhubarbdog
Post by rhubarbdog » Sat May 12, 2018 7:24 am
I have written a module to read an AOSONG am2320 temperature and humidity sensor using a 1 wire protocol on the raspberry pi and i have it working. I have translated it into microbit code the problem is when i collect the data i'm only getting a few bits (approx 3) spread over 100-120 readings when i run the corresponding code on my raspberry pi i get 38-40 bits (out of a possibe 40) spread over >1000 readings. The code is running in a while True: loop with no sleep why is performance so poor
