I have recently installed Mu Editor (version 1.0.0beta16) on My Windows 10 PC. Installation was a breeze and every 'Button' is working as I understood, except the 'Files' button.
(1) Based on some printed doc description, if I click the 'Files' Button, I can see two panes opened and the left one showing the files in my Micro:bit and the right one showing the files in my PC. I do get two panes. The right one is showing my ***.py files in my PC but the left pane is empty although I know I have successfully flashed the file into the Micro:bit (I know it is successful because the Micro:bit is behaving as I have scripted). Question number one is whether it is normal to see an empty left pane in this situation?
(2) I told myself perhaps the left pane can only show the ***.py file but not the hex file (which is the flashed resultant file). But if this is the reason I see an empty left pane, what is the point of having the left pane?
(3) I can drag a py file from the right pane (PC directory) to the left pane. But after dragging it to the left it is still a py file , not a hex file. So I cannot run it. Then isn't it no point of doing this dragging action?
I appreciate any advice, comments, guidance or even mockery (if I have totally misunderstood this button).
Many thanks in advance.
'Files' Button of Mu Editor
Re: 'Files' Button of Mu Editor
Flashed files disapear. Flashing wipes the microbit.
You put files onto the recently flashed microbit using Mu's file button or ufs (micro fs).
If you flash an empty script onto a microbit you can put main.py to be executed when you reset the microbit. Otherwise you need to import the secondary.py files in the script you flash/main.py.
Hi Rhubarb, Thanks for your post. But I am not sure if I fully understand.
(1) So you are saying that it is normal I do not see any HEX file shown on the left pane?
(2) Are you also saying that if I name my py file as main.py, I will see it in the left pane after flashing?
yes and yes.
Mu flashes a vanilla copy of a .hex file then puts your script as main.py
where as uflash creates an executable .hex file from a vanilla .hex file and the micro pythonscript your flashing
Thanks, Rhubarb. I'll explore and experiment a bit further (based on what you described) and see if I have a better gripping of this issue.
