micro:bit not working with 1.9.2
campy11
Post by campy11 » Thu Aug 30, 2018 1:43 am
One of my microbit seems to reject the 1.9.2 runtime.
uflash -r microbit-micropython-v1.7.9-gbe020eb.hex
and in REPL, i get
>>> MicroPython v1.7-9-gbe020eb on 2016-04-18; micro:bit with nRF51822
uflash microbit-micropython-v1.9.2-34-gd64154c73.hex
and I get nothing in REPL
In both instances, the device usb drive mount and unmount properly.
With v1.7.9, I can install and run programs. However seems that the accelerometer it not working.
I suspect the board is fried somehow. Before I toss it, anyone has any clue what could be the problem or how to diagnostic something like that?
shaoziyang
Re: micro:bit not working with 1.9.2
Post by shaoziyang » Thu Aug 30, 2018 7:57 am
My microbit is working fine in v1.9.2, maybe the new firmware is not good. you may try it in MU 1.0, it using micropython 1.9.2.
campy11
Post by campy11 » Fri Aug 31, 2018 5:58 pm
Thanks for the suggestion. Actually started with MU and that's how I realized there was a problem and tried to isolate it using uflash. Those runtimes work fine on another board, so I suspect this board to be defective. Unclear why that's affecting flashing new runtime.
rhubarbdog
Post by rhubarbdog » Tue Sep 04, 2018 4:48 pm
How are you entering a REPL session, using Mu or a program such as screen?
Have you tried running microbit.i2c.scan(), it should return a list of 2 integers [14, 29]. One is the address of the accelerometer, the other the compass
