ISR code example gives an error on microbit
Posted: Sun Oct 27, 2019 10:09 am
by rivandemo
I found an example of using ISR on this page: https://docs.micropython.org/en/latest/ ... rules.html but when i flash it on my microbit card it generates an error "no module named pyb".
Here is the code:
import pyb, micropython
class Foo(object):
    def __init__(self, timer, led):
        self.led = led
        timer.callback(self.cb)
    def cb(self, tim):
        self.led.toggle()
red = Foo(pyb.Timer(4, freq=1), pyb.LED(1))
green = Foo(pyb.Timer(2, freq=0.8), pyb.LED(2))
and i'm using Mu-editor 1.0.2 on Mac OSX 10.12.6 Sierra.
Btw, i had to split the first line in two import lines as multiple imports on one line is not accepted by Mu-editor.
Should i install the pyb module? And how?
Thanks for help,
Richard
Re: ISR code example gives an error on microbit
Posted: Sun Oct 27, 2019 12:37 pm
by shaoziyang
pyb module is for stm32/pyboard, microbit has no pyb module.
Posted: Sun Oct 27, 2019 1:22 pm
by rivandemo
Thank you!
Is there any way i can use interrupt (ISR) on a microbit? Iaw could you tell me where i can find documentation about this?
Thanks a lot,
Richard
Posted: Sun Oct 27, 2019 2:39 pm
by shaoziyang
microbit use nRF51822, and it has 16kb ram only. So some feather can't use in it.
Document for microbit:
https://microbit-micropython.readthedocs.io/en/latest/
Posted: Sun Oct 27, 2019 11:10 pm
by jimmo
The micro:bit uses a different version of MicroPython -- based on v1.9.2 https://github.com/bbcmicrobit/micropython
Because it's such a small microcontroller and because it's targeted at education, a lot of features are not available, including interrupts.
Depending on how adventurous you're feeling, you can actually compile the upstream version of MicroPython for micro:bit -- https://github.com/micropython/micropyt ... /ports/nrf which will give you access to some core features like interrupts, but you will lose some other features. And you probably won't be able to use Mu, etc.
What are you trying to do, perhaps we can find a way to do it without interrupts? (I've spent a lot of time teaching with the micro:bit and while we certainly did find the lack of interrupts frustrating, we did find a lot of ways around that limitation too).
Posted: Mon Oct 28, 2019 4:57 pm
by rivandemo
A few weeks ago i block-coded a simple program for my grandson to show him how to display his name on a microbit when button A was pressed and stopping the display when B was pressed. The issue was that when pressing button A again the display restarted from the beginning and not from the last character displayed. I then switched to Python and used a list and an index. The result was better but not completely satisfactory as the "button B pressed" check has to be synchronous with the "while True" loop.
I tried this:
import microbit
disp = 0
index = 0
maxIndex = 5
marcelList = ["M", "A", "R", "C", "E", "L"]
    if microbit.button_a.is_pressed():
        disp = 1
    if microbit.button_b.is_pressed():
        disp = 0
    if disp == 1:
        microbit.display.show(str(marcelList[index]))
        index = index + 1
        if index > maxIndex:
            index = 0
        microbit.sleep(1000)
I searched then on Internet an interrupt-based solution..
This being said, my problem is far from being important or urgent.
Richard
Posted: Tue Oct 29, 2019 1:40 am
by jimmo
hi Richard,
I'm not sure that interrupts necessarily make this easier.
The key thing though is that while the micro:bit is sleeping, it can't be doing anything else. So it helps to imagine how the sleep function itself works:
def sleep(delay_ms):
  t = running_time()
  while running_time() < t + delay_ms:
    pass
You can kind of implement your own version of sleep into the main loop of your program. In this case we figure out when the next letter should be shown.
import microbit
maxIndex = 5
next_letter_time = 0
disp = False
letter_delay = 1000
index = 0
        disp = True
        next_letter_time = microbit.running_time() + letter_delay
        disp = False
  if disp and microbit.running_time() > next_letter_time:
    index = index + 1
      index = 0
I genererally prefer to use was_pressed unless there's a specific reason to use is_pressed. The letters can be a string too, instead of a list. So here's a simplified version -- you also kind of don't need the "disp" variable anymore because next_letter_time != 0 implies disp = True.
import microbit
marcel = "MARCEL"
letter_delay = 1000
index = 0
  if microbit.button_a.was_pressed():
  if microbit.button_b.was_pressed():
  if next_letter_time > 0 and microbit.running_time() > next_letter_time:
    microbit.display.show(marcel[index])
    index = (index + 1) % len(marcel)
You might want to display.clear() when b is pressed too?
FYI I wrote this blog post about this exact topic a while back for my previous employer -- there might be some useful bits. https://medium.com/groklearning/become- ... b8b4e2d747 You might find their micro:bit simulator useful too (which you can access for free by starting the micro:bit course and going to any problem -- https://groklearning.com/microbit/), I used it to test the above code.
Posted: Sat Nov 02, 2019 5:53 pm
by rivandemo
Thanks a lot Jimmo,
I'll try the solution you recommend (sorry for this late answer, i have been busy these last days), and look at the two links you mention (actually i think i already followed the "Grok learning" course).
I used the "sleep" function to write this little program "quick and dirty" but i agree, i never use the equivalent function on Arduino (delay()) and always prefer the use of millis() combined with two variables (prevStep, increased each time the cycle occurs and cycleInterval, a self explanatory constant)
Thank you again,
Richard
